1 - 1 of 1 Posts
The “Lock-it” System is an innovative design from Hepco & Becker for mounting side cases to your bike while having the option to remove the mounting frames and return to the original look and style of your bike in a matter of seconds. Many riders do not use their luggage all the time, especially on short or daily rides, and would prefer not to have the mounting frames installed for reasons of aesthetics as well as practicality. The solution is the Lock-it system. There is a small initial attachment plate that is simply bolted to your bike without any drilling necessary. From that attachment plate, you simply attach the mounting frames using quarter-turn Lock-it fasteners. These fasteners have an Allen head pattern allowing for quick installation and removal of the side carriers, leaving you with an almost original look bike when not installed. All the Lock-it mounting systems will accept all of the hard side cases offered by Hepco & Becker!
Lock-It Side Carrier '17-
Journey Side Cases & Journey Top Case
Xplorer Left/Right Side Cases & Xplorer Top Case
1 - 1 of 1 Posts
