1 - 20 of 39 Posts
nice color fo sho
The wheel color code is 1329 Deep Purplish Blue Metallic (DPBM15) same as on the FZ8.. you can paint to match with this RS Motorbike Paint Online Store
Reactions: cjhorton
Reactions: cjhorton
fz9rider,
For the paint you listed, is this something that can be used to paint by hand? Like with a micro brush for small detail?
Thanks!
yes it looks like they have small touch up bottles available similar to those touch up pens you'd find at a parts store.. along with the ready to use aerosol for large touch up or trim pieces and larger bottles for mixing into an actual paint gun for full respray.
I sent a message today to colorright.com I believe they are the premier paint match company they actually use Yamaha's paint codes.
I've used them before and really like there paint.. the paint code for the wheels and all the body paint codes I listed in the Paint Match thread are all Yamaha paint codes. also any automotive body shop can "scan" match paint as well as access motorcycle paint codes.. I had some pieces from my ER-6n (candy plasma blue) painted at the collision center at the toyota dealership i work for and they just looked it up in there system.
Thats cool i want to paint the air vent covers that blurple color
Reactions: Lee Drew
that should look good.. I want to paint the tail side covers the same gray as the tank and then I'm having the front fender, air vents, and rear hugger re-done in carbon fiber.
Reactions: Lee Drew
I like what you're going to do with the tail covers. I want to install LED turn signals with the carbon fiber ones but I want an exact match as far as bolting it up have you found anything.
I've been looking but nothing of similar size and style yet
Glad you guys are working on this. Only 350 miles in and I have a couple of rock chips already.
Minuscule, but you know.... Brand new perfect bike.
Reactions: AzSportBiker
Bumping this...
I'm in desperate need of being able to fix this.. I have Colorrite.com hoping to help me out... They've taken the Yamaha codes of DPBM15 color code 1329 and will call me back... but on their system the code 1329 is just coming up as a base and not a color. I will also call Yamaha Motors out in California, and see if they're able to help... So far its not looking good...
Tire Automotive tire Alloy wheel Rim Wheel
1 - 20 of 39 Posts
