1 - 7 of 7 Posts
i just ordered a pair for 5 bucks you can't go wrong with the ingenious mounting even if they suck.
this is brilliant, assumign they hook right into the existing plate light connector? Dumb question but given the OEM plate light is just 1 light vs. this is 2 did you just splice them together?
Yeah, I just spliced them together. I spliced both red wires into a single wire with a male crimp on bullet and both black wires into a single wire with a male crimp on bullet. I twisted the wires together and just used a heat shrink on them to hold them together. That way I can still plug and unplug them from the tail light harness and just cut the heat shrinks if I ever need to remove/replace them. I actually used wires with female crimp on bullets and crushed them into males.
View attachment 3862 View attachment 3863
right on thanks for sharing - pumped to install these.
1 - 7 of 7 Posts
