1 - 11 of 11 Posts
I probably weight 210 geared, and was riding on the factory suspension settings. Couple dozen accidental wheelies later I noticed my right fork leaves a small film of oil residue when I compress the fork. Now I'm thinking it is a good time to upgrade the springs and oil while I'm at it. Any DIY's on how to remove the forks and replace the seals? :( Any recommendations for springs and oil?
.95 sonic springs and 10w maxima oil, oem seals. You can find the Yamaha service manual in pdf form extremely easily.
I tried to diy a fork seal driver, do yourself a favor and just buy one. 41mm. Also for $45 get a proper spring compressor.
Fork spring compressor tool
Yes the Traxxion tool works, but you need a third hand to slip the slotted keeper under the nut. If you have significant other or a brother law you can't get rid of, that will work fine. I built my own with some scrap iron, I had around. You may notice I changed the spacer tube capture bolts locations after I first built it and tried it out. The last photo on the floor with the tire is the first design. The first two photos is a better set up for the 3/8" bolts to hold the spacer sleeve.
Machine Toolroom Machine tool Workbench Tool
Machine Machine tool Milling Toolroom Tool and cutter grinder
Tire Wheel Automotive tire Bicycle part Rim
My leak has gotten progressively worse from all the wheelies I do, so I'm finally going to try to do this by the end of the week.
The service manual calls for a damper rod holder. Can I get by without this?
My friend,
Go to any site, and order you a Motion Pro fork seal tool.
From my mx days, I can promise you that brand new seals will leak just like the ones on there. It just takes a tiny fragment of anything under that seal to leak.
This tool is around 4 bucks and you can use it over and over. Each wash etc, it has totally redefined fork seal leak issues!~
My friend,
I'll do that in the future if I ever have a small leak. But my current seal is trashed to the point of spraying oil out when compressing the fork. I'm still wondering If I need the damper rod holder tool because I'm upgrading to heavier springs and oil.
1 - 11 of 11 Posts
