G'day all, I've a 15 MT09, 38000k's (23000 miles) and lately the issue has been, only in 4th gear, what feels like the ignition cutting out (like lifting the quick shifter not quite far enough to change gear) or something in the gearbox not engaging fully and dropping in and out while coasting then accelerating. It does not drop out of gear, and changes gear up and down without noticable problems.
I have disconnected the quick shifter and the issue still exists.
I found the clutch basket cracked and one fibre disk in pieces. Second one out from the inner of the basket.
These have both been replaced and the issue is still present, only in 4th gear. All other clutch components are within factory specs.
Oil and filter have been changed and no visible metal particles detected.
Chain and sprockets are are within wear limits and correctly adjusted.
Short of removing the gearbox, stripping and inspecting it, has anyone got any suggestions or experienced a similar problem??
