1 - 20 of 28 Posts
In the state of New York, the inspection sticker for motorcycles is supposed to be on the front left part of the bike:
"ALL MOTORCYCLES REGISTERED IN NEW YORK STATE must be inspected and display an inspection sticker on the left front side of the motorcycle attached to a structural member. Bolt on plates may be used."
Source: Required Motorcycle Equipment - Text Only
This has led to the dealer having stuck the sticker on the left fork leg and it looks really ugly there and has been bothering me since day 1. If I take it out of there, where can I even put it? Any suggestions? I thought about inside the steering/air scoop area. Would that be legally valid? it is, sort of, in the front...where have you guys placed this?
You guys have to inspect new vehicles? A new car here is exempt from inspections for two years or 50k miles and 1 year or 25k miles for bikes. Its weird that a BRAND NEW vehicle even needs to be inspected.
Reactions: Lee Drew
Yeah, it sucks. It has to be done every year. Plus, in NY all registrations have to be renewed in April, irrespective of when the bike was bought!
I stick my inspection sticker up the state of NY's ass, I never get my bikes inspected. It's a joke the inspector checks the brake lights and the tail light/ headlight.
Until the State keeps me from being able to renew my registration, no inspections!
Pa. Has them on the same place I know it sucks. But if you remove them yourself they become invalid. Don't ask how I know. I've never taken off a motorcycle sticker but the car stickers come off with a heat gun quite nice. But they don't stick as good after that. Don't ask how I know.
terrible...
Surprisingly in MA they only require a sticker on the license plate...so nothing touches the bike itself :cool:[/QUO
Now that sounds like a good place to put it. Or just move to a state that does not do inspections, problem solved.
Reactions: ben58
anodizing
Will removing the sticker with a heat gun or gasoline ruin the anodizing on the fork?
I know that's where there going to put the inspection sticker on the fork, but next time I would like to have it on a plate, somewhere less noticeable.
the last time I got my dual sport inspected, I neglected to ask them to put it on the inspection plate, so they put the inspection sticker on the fork. geesh.
that's what I was thinking,
there is a bracket that you can install below the license plate, for the inspection sticker, barley noticeable. made by "Chris Products Inspection Sticker Plate"
then there is the kind that install over the fork with hardware. anyone know what size the fork is in millimeters?
the only reason I ask, is because of the scraping or removal of the sticker next year, rather have the sticker on a inspection tag somewhere.
do you have a link to the thread?
did you do a write up on the materials you used?
No, I didn't post anything other than the finished. It's .063" T-3 aluminum. It was bent perpendicular to the grain using a bend radius that doesn't cause undue stress in the part, probably .250". The mounting hole was then added .198", and then edge distance around the hole was marked (.375"), and the excess was cut off. Smoothing all the edges, debur the hole, alodine (if you have it), prime and paint.
I don't understand the rationale behind having it mounted on the side of the bike. From an enforcement point of view wouldn't it be easier for a cop to just follow you and see the sticker on the plate like most states. With it on the side (especially the left side) it seems like it would be harder to spot people with expired stickers.
Sent from my SM-G920V using Tapatalk
1 - 20 of 28 Posts
