1 - 4 of 4 Posts
'15
Don't want to shell out $80(CAD) for a new switch? Can you solder? Cut it apart and fix it up! The problem that happens is the solder fails on the internal conectors and the glue is the only thing holding them in contact with each other, causing intermittent gear indication on the display gauge.
Total Time 30-60 mins.
Difficulty level 2/10.
'15
Discussion Starter · #2 ·
Just a little follow up - this fix worked great, all gears show on my gauge cluster now. Before the fix it only showed neutral and 2nd gear and would flash in and out of 3rd gear occasionally.
1 - 4 of 4 Posts
