looks like i’ve sprung a leak from somewhere in my cooling system, oil still looks fine through my sight glass. Highest spot i can see dripping is about halfway down my radiator on the left side. I went on a longer ride earlier today (100 miles or so) and smelled a slight sweet smell whenever i got home but didn’t think too much of it. It was windy and my fan never even came on as i was moving pretty good the whole time. Plus i didn’t see much if any antifreeze dried onto it. However after returning from a ride to the gas station around the corner tonight i noticed the smell again and it was dripping off the bike in certain areas, plus had dried on from just the short ride (less than 1/2 mile) My radiator hoses feel empty now, and i haven’t checked the level of my rad because i can’t get to the cap behind the shroud because all my tools aren’t with me. The reservoir is still full tho. I’ve got a radiator guard also, so i’m surprised this happened. With the spray pattern do you think it could be coming from somewhere besides the hole i think i’m seeing in the third photo, where the fins are darker because they’re wet and because it’s the highest spot that looks wet i assume that’s where the leak is from but i’m not sure. Any tips or stuff i should look out for before i repair? Im Going to fill radiator and run till hot, then see if i can find the leak and make sure fan comes on. Maybe i’ll be lucky and it’s just a loose clamp or something somewhere
