1 - 8 of 8 Posts
Im not sure if anyone else is seeing a similar issue. Im having a slight throttle hesitation when exiting a corner, and/or while riding at a constant speed and then trying to accelerate. I think its around 2nd/3rd gear, maybe 5/6k rpms. My "fix" is just to clutch in, and release and the problem goes away. Im not sure what to think. Maybe fueling?
my mods are Akra carbon full exhaust, K&N air filter, and PCV with Dynojet's map for Akra full exhaust with stock filter.
I will be updating the map soon, with a map that they suggested. Their suggestion is still not specifically for the K&N and exhaust. But they have also suggested to get a custom tune, that I just havent done yet.
Any input will be appreciated.
I've never had any luck with their canned maps... Quite contrary. I do know that my Akra flash is insanely well fueled and crazy smooth. Something I've never experienced with piggyback controller.
PM me your email address & I will send you my custom PCV map to try.
2014 latest Yamaha flash, Akra carbon, DNA filter, snorkel removed, my O2 controller.
Thanks kevxtx! PM'd
Will check those vcyclenut.
Thanks for your input guys!
I was noticing on colder days this winter that the injectors would cut out in almost any gear when I was at around 4500-5000 rpm and holding steady with about 5% throttle. Seems to have gone away now the weather is warming.
Reactions: fatfurious2
I hope that is the case.
Kevxtx, I havent gotten to try to the map yet, but I will, and report back.
1 - 8 of 8 Posts
