1 - 1 of 1 Posts
The Mininrack by Hepco & Becker offers a slim, light weight, and unobtrusive luggage solution for those on the go. The Minirack is a small aluminum rack cut out of aircraft-grade aluminum with the use of a CNC machine. This allows for a perfectly symmetrical shape and cut-outs where you are able to strap luggage down. All Miniracks and mounts have a black powder coat finish and are supplied with stainless steel hardware. This rack attaches to the bike using mounting frames and hardware provided in the kit. Everything you need to install this item is provided with the purchase of the Minirack! Perfect for your FZ-09 ;)
Check out the Minirack for the 2017- FZ09 here!
1 - 1 of 1 Posts
