1 - 20 of 32 Posts
Myself being bloody useless with tools, I took the plunge and decided to save some cash and install the racing line Akrapovic myself.
165224
Headers went in flush. Did have to tighten them a bit to ensure they were well-sealed.
165225
This arsehole plastic 'screw' that isnt a real screw was very frustrating to remove in order to get the side panel of the radiator off.
165226
7 bloody hours later. That was incredibly stressful. The space around the header bolts behind the radiator is SO cramped.
165227
Winter ride through the small town of Uralla NSW.
1 degree Celsius through Bendemeer :eek: My hands were not enjoying that part. Heated grips incoming.
Tire Wheel Sky Plant Fuel tank
Got some Oxford heated grips.
Decided to get rid of the Praying Mantis stock mirrors and replace them with some bar end mirrors.
The inside of the bars is in there pretty damn tight, but luckily bolt for the mirrors I bought fit right in the threads of the OEM bar ends.
165230
Had to add some spacers AKA filed down, 40 cent washers from bunnings, otherwise the throttle would stay pinned in place after accelerating :eek:
165231
Mirrors on, throttle turns and returns to off when released.
165232
Installed a fender eliminator from Mustard Bikes.
165233
Excuse the water. It was pissing down on my way home.
Very good quality fender eliminator. Tolerances are dead on and flush.
165234
Could pull the LED plate illuminator inside a bit more, but here is the underside.
165235
Pretty easy install!
165236
165240
What exactly is the ribbed/ finned item sitting inside the bike frame immediately below the rider's seat and outboard (in this view) of the yellow shock spring. I assume a part of the electrical system - rectifier maybe? - but being electronologically illiterate wouldn't bet my house on it. More to the point, it's not a pretty look, IMHO a bit unfinished, and I imagine that some style of aftermarket cover may be in the offing soon enough. But I also assume that its finned nature implies some sort of heat source, so would any damage occur if it's sealed in? Bike looks good!
Reactions: kevxtx
It is the regulator/rectifier. Converts AC to DC for the battery. I just replied to another friend on facebook about it. Funny that. I hope a cover does come out. The cover could be resigned to have some sort of duct for air flow/cooling. Would be a good idea. As for the yellow, its apart of the Ohlins package.
Thanks, hardy. I am aware of the yellow Ohlins stuff - have had it on earlier SP and a late BMW R9T - but the other bit had me puzzled. I have some lovely woven stainless mesh that would look good as a 'breathable' cover in that location, and it would also go nicely with the adjacent polished alloy of the new rear swingarms.
I do not know where it is placed on the FZ, but the MT, it is most awesomely located under the seat. I can only assume they moved it from that location to the side and made it so prominent cause something was going on with the under seat location?
2021 Yamaha MT-09 SP
Wow you have great taste in motorcycle mods
are those CRG arrow bar end mirrors? How well can you see compared to the stock mirror?
1 - 20 of 32 Posts
