1 - 8 of 8 Posts
Anyone Hardwire a Battery tender, GPS or phone charger? If so did you install a fuse box or go directly to the battery?
Every connection to the battery should be fused.
I use battery tender's "pigtail" connector that includes an in-line fuse holder to connect the battery tender and other accessories.
Reactions: RBC and Davinci
The fuzeblock is a great item if you are going to be having accessories other than the battery tender.
You can also make your own switched DC circuit using a $5 relay as well.
Can't believe I'm thinking about wiring in a phone charger. Why, back in my day.....never mind.....:p
That's good to know. Just thinking of GPS and phone charger. B
I always go direct with the battery tender.
1 - 8 of 8 Posts
