1 - 14 of 14 Posts
Hey guys thinking of getting some handguards and heated grips.
For the handguards thinking of either the SW-Motech Kobra Handguards ( doesnt look like too much protection but I think I can buy extensions)
or the ones Givi makes. Also barkbuster makes a set "storm".
Links : Givi HP2115 , SW-Motech Kobra , Barkbuster Storm
Was seeing if anyone had any experience with either of these before I purchase
For heated grips trying to decide between the Oxfords (great reviews) and the Yamaha OEM ones. The Yamaha ones I know plug right into my 2017 but I have seen
some poor reviews on them. Not sure if these are accurate or not. The oxfords seem to have gotten pretty solid reviews and have an auto shutoff feature. The grips themselves
seem higher quality than the Yamaha OEM ones.
Thanks guys!
I bought the Koso Apollo heated grips. The light on the left grip tells me in a moment where they're set (or if I forgot to turn them off - mine are wired direct at this point). Push button for easy set on the fly. Not one complaint with them, I would buy them again. They are a bit pricey, but worth the extra in my book.
Can't speak for any of the products you listed, but I have the Symtec Heat Demons (with the plastic rocker switch) and they get nice and toasty. If you're getting hand guards these would be more than adequate. Factor in a couple extra bucks for new grips though because you'll have to cut the OEMs off to install. My switch is mounted inconspicuously using the bottom bolt from the left mirror and is reachable while holding the grip.
With just the heated grips and some cold weather riding gloves I can usually do my 20 minute work commute on the highway with temps into the low 20s (without guards). If you decide on a set of guards to block the wind you could probably go all day in freezing weather with the combination of the two.
Don't think I've seen this yet... but has anyone used heated grips with other "grips" over the heating elements? Or are they integrated into the grip material itself.
For example, I really like my pillow-top MX grips, but it would be nice to have them heated.
I suppose you're stuck with whatever grip the heated ones come with.
Someone sells an element that you fit under your own grip, don't remember where I saw them. Not sure how effective they would be, they may heat the handlebars more than the grip.
Heated grips I believe tend to be a bit bigger diameter than standard grips.
The ones I linked in my last post are exactly as you described. Put the heating element on the bar (with a layer or two of electrical tape beneath to insulate), then put a pair of grips of your choosing on top.
They work surprisingly well.
Ah no shit. Cool. I’ll check them out.
Just bought a pair. Looking forward to installing.
Thanks guys!
I drive below 32F as long as there’s no ice or snow (I live in Canada). I’ve set myself up with Oxford “Hot Hands” over grip heaters and Barkbusters “BBZ” handguards.
My grips feel fat but the benefit is I can keep on whatever normal grips I’m using and just throw on Oxford heaters when needed. These have only one setting, effing HOT so you sometimes have to turn them off to regulate heat. A small price to pay for the convenience factor.
I’ve used regular oxford grips before and they ended to melting and became useless. Too hot in the summer heat?
The handguards are awesome because they actually wrap around your hand as opposed to just breaking the wind 4” in front of your hand and the wind still wraps around.
Come summer time I’m back to my beloved stock setup in about 10 min.
Will post a pic tomorrow.
I've got Oxford heated grips (sport) - they are great. Auto Power of and you can set the heat from 20% up..
Sent from my SM-G930F using Tapatalk
i have the Yamaha heated grips ( pre/wired also in my 2019 MT 09) and i have a Acerbis Handguards.
The Yamaha heated grip i love , the Acerbis doing an ok job to keep my hand shielded from the cold wind
157634
157635
157636
. Not much from the really cold wind though. You still feel the wind a bit. But with the heated grips they work just fine, even with my summer leather Alpinestar gloves.
Some years ago I had Oxford grips. They failed on one long cold trip, but luckily stuck on hot. 2 sets later I got a set that lasted the next 3 years before dying. I hope their QC is better now.
The auto shut off was not auto enough to leave enough voltage to start my bike. I had to fit a relay triggered off the rear light to make sure they were off when stopped.
The Yamaha grips are so much neater than most of the other units, so they were a no-brainer for me (same thought process for the Yamaha rear rack). They are plenty hot enough if they are set up right - there are three different maximum (heat) wattages depending on the power output of the alternator of the machine to which they are mounted.
I bought hand guards my first winter riding and they made little to no difference for me (and I wasn't a big fan of the aesthetics personally). I've since purchased the Fly Racing battery powered gloves and haven't looked back. I'm on winter three with them and just rode to work earlier this week in 8* F weather with the heat setting on medium.
Never have tested heated grips tho.
1 - 14 of 14 Posts
