1 - 10 of 10 Posts
I am assuming that they will work with the yoshi eliminator kit?
You will need adapters for the bracket. I have seen some using washers painted black
You will not need adapters, the signals come with everything you will need to install them.
Personally, I felt the signals were a little too hidden by the plate, so I used the base of the stock signals to move them outward a little.
Finally got mine in works like a charm just have to reassemble - out of curiosity, where did you end up strapping the resistors, and had any problems with them thus far?
I did not use the resistors, I just replaced the flasher relay with this so I wouldn't need them. The resistors are too bulky, IMHO.
Here's the location of the flasher relay if you want to do the same.
.....and no problems so far.
Sweet man - thanks a ton for that. Ordered and I'll deal with the quick flash for the time being. Thanks again.
1 - 10 of 10 Posts
