1 - 20 of 46 Posts
I was looking into getting a go pro for my 09. I was wondering where you could get good mounting kits. I've never had one on any of my bikes so I'm open to any viewing angle. Any advice with this topic is greatly appreciated!
The swing arm or tank works well. I always just used a suction cup. Helmet works as well, gotta use the sticky things it comes with for that.
Sent from my XT1080 using Tapatalk
What is the least likely to vibrate and pixelate the video?
I would assume vibration on the handle bars. Can you guys chime in on quality of recording
on rougher roads or higher speeds?
Thanks
Just watch out for lean angles on your swingarm. I've ground down a GoPro case that way not thinking it thru. But the swingarm spool makes a great mounting point.
Thanks
I tried both gas tank with suction cup and mirror post with bicycle clamps. The gas tank seemed to shake, while the mirror post seems most stable.
If I get a GoPro I want to make a mount that goes forward from the frame slider so the cam is a little forward of the lower right radiator corner.
I used the sticky mount plate and mounted it on the front brake master cylinder. I put two semi circle on either side to allow taking the reservoir off for maintenance. The slide in mount is loose fitting and vibrates some.
I've had it under the tail, on the bars and on the tank. Now that I have my stock mirrors removed, I'll probably get a more "permanent" mount there. Seems like a good view angle (no speedo!) and will stay locked in tight.
Reactions: Niner
Ahhh. Is there any way to use the empty mirror threads?
I thought I saw someone use that before.
A bunch of guys used their mirror holes on their SVs but because ours are reversed thread I haven't seen the same mount...
Sent from my hot secretary, dictated but not read
RAM Mirror Post Base for Harley-Davidson Motorcycles
Ram Mount makes one but it's $50. I've been considering getting the $5 GoPro universal tripod mount:
Amazon.com : GoPro Tripod Mount : Tripod Heads : Camera & Photo
And finding a way to affix it to the empty mirror post threading. I'm sure many other bikers have done it in the past but I haven't researched it yet. :D
Reactions: Niner
I have various GoPro and RAM mounts that I have used on track & street bikes. I recently installed this RAM mount on my 09, RAM Mount Motorcycle Handlebar Clamp RAM-B-367U. The bolt simply replaces one of your handlebar clamp bolts. I cannot comment about vibration or video quality because I have not used the GoPro with this mount yet. However, it is at the stiffest point along the handlebars so there should be less vibration than say at the mirror connection.
Reactions: ridethepiggy
That one is pretty cool but then I'd have to buy a Ram mount connection for my GoPro! :sad5:
1 - 20 of 46 Posts
