1 - 4 of 4 Posts
So after googling I found 8 fast flashes means fuel pump is bad, but I pulled the tank apart test Ohms for the pump and fuel level, then put the leads directly to the battery and pump fired right up. tested the relay and the relay is junk. has this happened to anyone else? If so were their any other problems that you ran into after the new relay or other causes that caused this issue. It's been a few weeks since I've been able to ride and losing my mind. No engine warning light and its already been hooked up to the OBDII so no errors without a light.
160372
Hasn't happened to me but I have heard others having the issue. It's been discussed on other threads around here. I have a spare relay sitting on the shelf just in case.
And yeah, nice picture.
No problem here, but where was that picture taken?
1 - 4 of 4 Posts
