1 - 3 of 3 Posts
Hey saw a post from like 2014 about this but wanted to double check. Could this just be a relay or a fuse?
Hazards work all around. Right blinker does not work at front or rear. Left blinker works front and rear.
No clicking or anything. It's like hitting right doesn't even work. All stock lights. Picked it up from a dealer on Long Island. Going to either drop it at them for a few days. Or if I can order the part and just plug and play I wouldn't mind doing that.
Nah, if the hazards work, the relay and fuse are good. Problem is going to be either in the turn signal switch, or the wiring.
Try opening up the switch cluster and spraying a bit of contact cleaner into the switch, maybe that will clear it up. If not, hope you're good with a multimeter lol
1 - 3 of 3 Posts
