1 - 16 of 16 Posts
I, along with pretty much everyone, hate the tumor that is hanging off the back of the FZ. I decided to do a budget eliminator. I havent figured out what im going to do about the rear turns yet but so far my fender and signal eliminator cost me $8.80 with tax. Hopefully the pics will work otherwise I will post them from my computer.
On the front I made the running lights the turns since the headlight will likely be on whenever the bike is on. I may get yellow bulbs for it. So far cost is $0
Standby for pics
Discussion Starter · #2 ·
Here are the pics as promised
Here are the integrated front turn signals. cost $0
wired the turn light in to the running light. the running lights dont come on but i dont need it anyway. i will eventually put colored bulbs in.
On the rear, i went to walmart and got a 7 pin trailer plug(truck side) cost $8 and cut the cap off
I removed the abomination hanging off the back and found that the plug cover covered up the wiring hole and lock perfectly
i drilled the four holes ( 2 into the subframe and 2 into plastic) you need to take the hardware holding the side cover loose. not off just loose and put some screws in.
please note that you need to grind the cover flat on the back and remove the tab thats on the flap of the trailer cover otherwise it hits the lock. i just screwed the plate in to the undertail hopefully the police dont say anything. if they do i can just bend it down. i dont have rear tuns yet. im still trying to figure out a solution but will probably go integrated. 20140714_110537.jpg 20140714_110545.jpg 20140714_110552.jpg 20140714_110612.jpg 20140714_111137.jpg
Nice job on the 7-pin connector cover!
I'm also running the 'integrated' turn signals, but in conjunction with a standard set of LED signals. Been playing around with various LED's to get the right amber color/fill.
David - just a matter of connecting the hot line going into the marker lights to the existing turn signal circuits. As DVM mentioned...minutes of your time.
yep just a few minutes. remove the side covers and clip the hot wire for the marker light (blue i think) and i just clipped off the connector from the turn signals and solder the turn wire to the wire on bulb. it was free, i would recommend using adhesive lined heatshrink(marine grade) on the joint. you can also order the connectors for the turns off ebay. i ordered some that looked the same that i will use for the back so i wont have to cut the stock turns.
Thanks! BTW checkout superbrightleds.com for the amber color LED's I currently am running red ones but they have all different colors
No Problems from the Po-Po??? I don't think we can get away with that in Colorado unless it was an emergency vehicle. I could be wrong.
View attachment 7964 View attachment 7965
Now go out and put direct sunlight on your headlight and see if you can see them from 20 ft away with the headlight on. I'm curious myself if they show up.
1 - 16 of 16 Posts
