Status
Not open for further replies.
1 - 1 of 1 Posts
EJK FUEL CONTROLLER INSTALATION INSTRUCTIONS
Before starting the installation of your EJK fuel controller, let’s make sure you have the following tools available.
• 4mm Allen key
• 5mm Allen Key
• 10mm socket and ratchet
• Pliers
• Flush cuts or cutters
• 8 tie raps
First step is to remove your seat and fuel tank. Starting with the side plastic covers, remove the bolt on each side with the 4mm Allen key. Then remove the push pins by pushing the middle piece in and pulling it out. Same with the cover behind the handlebars. From there you can remove the 6mm bolts with the 10mm socket.
View attachment 1392 View attachment 1389 View attachment 1390 View attachment 1391
1 - 1 of 1 Posts
Status
