No, same. Would have matched my set I already had. I have individual pics available too. Should've mentioned that in the add. Oops.Is the brake line a different size for this MC? I already has SS lines, so just curious.
Not sure of your point. The new cable goes with the new MC, same size as the other SS lines. Banjo connection has nothing to do with that....I'm selling a kit here. Hopefully I'm not confusing anyone.The orientation of the banjo connection is different on the radial MC.
@Sherwood asked if it was the same line.Not sure of your point. The new cable goes with the new MC, same size as the other SS lines. Banjo connection has nothing to do with that....I'm selling a kit here. Hopefully I'm not confusing anyone.
The banjo will need to be different for the radial MC, so if his line doesnt have the ability to swap the banjo (some dont) then he will need the line that comes with your kit.
[/QUOT
Why are you doing this? What is your agenda? Do you go around messing with people's ads just for fun? There is no other reason I can think of to try and confuse someone....it's just not worth it. Thanks so much@Sherwood asked if it was the same line.
My agenda?Why are you doing this? What is your agenda? Do you go around messing with people's ads just for fun? There is no other reason I can think of to try and confuse someone....it's just not worth it. Thanks so much
