1 - 3 of 3 Posts
I don't have a manual yet, so I need to ask: what's the recommended maximum runout spec for the front rotors? The right is about .0015, but the left is around .00325. I was getting a slight slow speed pulse, but I'm not sure if it is pad related or not...
Mothy, according to the manual: 'Brake disc runout limit(as measured on the wheel)--0.10mm(0.0039 in)'
'Brake disc thickness limit: 4.0mm(0.16in)'
Hope this helps you...
Thanks! I figured it was close...
1 - 3 of 3 Posts
