1 - 9 of 9 Posts
For those that have removed the front fork reflectors did anyone use a washer or just reinstall the bolt?
I just put the bolt back in and it tightened up the way it should but was curious if a washer was needed to fill the gap of the bracket.
Probably a dumb question but im wondering! lol Thanks!
I will probably just buy afew washers with the same size and thickness.I noticed the left reflector tab touches the caliper,no need for it to be that close.
I didn't use any washers.....
How long ago did you take them off,any issues?
I took them off the day I brought the bike home last month.....just over 1000 miles now and no issues
you don't need washers. Out of the four bikes I've had in the past 6 years, none have ever had any washers behind a caliper bolt. Not needed and would serve no purpose. Which is exactly why there is not one on the bottom caliper bolt.
1 - 9 of 9 Posts
