1 - 10 of 10 Posts
are my brake rotors installed correctly? do they only go on 1 way?
i already put loctite and tightend
They look fine, if they were inside out, you'd see the lack of paint and imprint from the flange suface of the wheel. But they aren't directional so it doesn't really matter
yeah, im going to have my pr4 mounted and balanced and new bearings installed, so ill compare it to the fz09 on the floor
btw got my new brake pedal, but they have not shipped the pedal bolt yet so i used old 1 to make sure everything works
(i rounded off taking it off
i got my tire mounted and balanced, and the bearings pressed in today
the shop was once again very professional, and took care of my wheel without a single scratch, they also confirmed the way i installed the rotors was correct, i even took a look at the 09s on the showroom floor and the rotors were offset too
i tech told me that there was 2 bearings that i would need to buy for the clutch cover, is there anything else i need for replacing a rashed clutct cover?
i also got to watch them rebuild a crate damaged fj09
1 - 10 of 10 Posts
