1 - 20 of 72 Posts
Think there's any possibility of the R1 forks, brakes etc swapping over?
I'll be finding out when I get mine, I have a front end off an '08 :p
If it doesn't work, just means it's going onto the Warrior :D
What might our other options be if the R1 bits don't work?
I would be swapping my Ohlins FRT forks in, if it fit.
Anybody know of other forks we could swap into FZ-09? If the total fork length and travel are close it would be worth trying ebay for this upgrade.
Stock specs seem to be:
5.4" travel
41 mm diameter sliders (inner fork tubes)
50 mm diameter outer fork tube in the top triple clamp
52 mm diameter outer fork tube in the bottom triple clamp
21.25 inches long for the outer fork tube
30.5 inches in total length from the top of the fork to the center of the 22mm axle
Thanks
I just measured my 05 R1 shocks and the are 28.5 from center of axle to top. They are quite a bit shorter.
How much shorter? That might not necessarily be a bad thing, a lot of the guys have been saying they'd like to either lower the front, or raise the rear of the bike some.
Personally, I just really like the idea of the better brakes, and getting rid of the gold forks. And it's an opportunity to powdercoat the wheels anyway. Wonder if the FZ fender will fit, or if you'll need an R1 front fender too?
2", 30.5" vs. 28.5". That's 50mm, which is a lot. Rough rule of thumb is that 3mm of ride height equals 1mm of trail, so close to 11mm less trail. That's a huge change.
Discussion Starter · #13 ·
Thanks for the info.
Now just playing devils advocate here, those are the extended / unloaded lengths correct? So once the front end is loaded, the FZ forks are going to compress more and that should put the numbers closer together. But you're right, that is a big difference...
Yamaha claims 103 mm trail, for the sake of comparison the Triumph Street Triple claims 99.6 mm
Well, you should be setup with the same sag, and ideally the same spring rate, so that should be a wash. Other variable is triple clamp offset, that directly affects trail.
Lots more to consider on fork swaps beyond "will it bolt up". :)
I know alot of people are not crazy about the gold forks and well the guys over on the yamaha stryker are starting to use plasti dip the cool thing about it is if you dont like it you just peel it off and your back to gold. Do a search see what you think? Nothing to lose.
Reactions: fz9-tx-guy
Discussion Starter · #18 ·
I guess I was going off of the stock spring rates, the R1 rate is about 20% stiffer than the FZ.
If you have the time, would you mind going into more detail about what kind of impact the shorter forks would have on the bike? You clearly know more about this than I do, although I want to learn. Thanks in advance :)
The short answer is it will quicken your steering. 2 inches is a lot very possible that is enough to make it unstable. If you were lowering the front to quicken the steering you'd likely do it in 1/8 to 1/4 inch increments. IMO if the issue is the fork color then change the color of the stock forks, way easier and you won't be the Guinea pig for how low a 09 front end can go. ;)
1 - 20 of 72 Posts
