1 - 20 of 51 Posts
I just received a set of signals from Motodynamic. They are meant for the FZ6R but from what I read they fit just fine to the FZ09.
I'll be posting photos of the install
Damn, i like the look of those better than the protons i just ordered. What was the cost?
I will need to demel out the housing to get them flush but for $45 Im happy. I think I may swap out the headlight edge bulbs for amber and wire them into the signals as well for better from flasher visibility.
Discussion Starter · #8 · (Edited)
That looks great. How long did the install take you?
I did it at work in 20 mins. Just 4 screws to remove the housing on each side and then remove the seat to install the resistors. If you install them in the front lights they dont act as running. The fit isn't perfect but nothing a dremel cant fix.
https://dl.dropboxusercontent.com/u/458255/FZ09.org/2014-05-16 10.48.36.jpg
https://dl.dropboxusercontent.com/u/458255/FZ09.org/2014-05-16 10.47.53.jpg
They also include little tear drop shaped rubber pieces that go around the edge.
Flush mounts on this bike look good. But functionality is a huge concern because they are almost invisible to oncoming traffic. The only flush mount I would install on the FZ would be a Watsen Design since they are as bright as the Sun!
Reactions: DECON BLUE and mxlu
1 - 20 of 51 Posts
