Hi all,
I have posted about flash tune previously, but it was all theoretical at that point. I finally bit the bullet and ordered a Termignoni titanium exhaust and FT bench kit for my bike which is a 2015 UK MT-09 with ABS. I have 0 previous experience mapping ECUs, although I do have some qualified friends that have non-FT mapping experience who are willing to help, but obviously they aren't going to know everything. The reason I didn't use a mail in flash service is because I simply don't know who is good in the UK and I didn't want the risk/cost of sending it to the US.
My goal is to make the bike run right with this exhaust, I am not worried about squeezing every last ounce of power out of it, I just want it to run correctly and to smooth out the throttle and avoid doing damage in the process.
I have some questions below, so please weigh in.
Any feedback on the above is greatly welcomed and appreciated, as are any other recommendations or comments that you think might help. I am aware that I am a complete newbie to this, so if I ask a stupid question please forgive my ignorance.
Dave.
- Is the unrestricted flash from FT going to be ok to run on my bike?
- Does the unrestricted FT map run too lean/rich?
- Would you recommend I purchase a wideband O2 sensor and display to monitor the fuelling?
- Am I ok to leave closed loop disabled?
- If I leave closed loop disabled are the fuel maps ok as they are or should I tweak them?
- Should I import a PC map?
- Would you recommend leaving closed loop enabled and running an O2 mod like kevs?
- How much so you think this map improve the snatchyness of the throttle?
Dave.
