1 - 11 of 11 Posts
So the FJ and FZ have the same frame and engine, but the FJ supposedly has a longer swingarm, anyone thought about doing that swap? I wouldnt do it, but maybe one of you turbo or drag racer guys would be into it. Im just curious to see if it would be a bolt on affair, plus chain and maybe brake hose. Any thoughts or inputs yall??
The Yamaha site list the wheel base for both bikes at 56.7". Maybe the difference in rake angle makes up for the a longer swingarm?
If you check the spec's both bikes do have the same wheelbase of 1,440 mm (56.7")
But if you take a close look at the two pictures, the FJ's license plate holder stick out quite a bit further than the FZ's.
Birdman, what is your goal, and how much longer are you interested in? I haven't investigated, but it seems there is plenty of axle adjustment for putting on a longer chain.
If you want to smooth out the handling consider the GPR steering damper, about $500 but a new swingarm isn't cheap either lol.
1 - 11 of 11 Posts
