1 - 20 of 27 Posts
Fixing to do my first 600 mile oil change. Looking in the "Periodic Maintenance" section of FZ09 guide, page 3-23, calls for a gasket between drain bolt and crankcase... After inspecting by bike (and all my other bikes) seems to be metal against metal, no extra gasket. Can someone help me verify if I need this extra part or is the bolt got a flat head/washer type surface? hoping not have to go to dealer for a little gasket if not necessary...
Thank you kindly :)
Should be a copper crush washer.
Sometimes the washer looks like it's part of the bolt. Mine was crushed so tightly i had to pry it off...
The washer appears to be part of the drain plug. So all you need is oil and an oil filter. Good luck taking your original filter off the first time.
Ride Safe.
Ride Safe.
Just make sure you use the right kind of filter wrench. The best type is one that works off a ratchet, and clamps down tighter as you turn. So the harder it is to turn, the harder the jaws clamp down all around the filter. I've never found a filter that can't be removed since getting that tool. Here's what it looks like.
Technology Electronic device
According to the parts list, it a gasket, which should be a softer metal alloy material that you should be able to use a couple of times. Lots of times it is an aluminium washer, that is a specific size and to buy one is not to expensive. A lot of cars use this same idea to help seal the drain plug, and it needs to be replaced once in a while.
Text Diagram Font
The dealer should be installing a new drain plug washer (gasket) at every oil change. I know on some bikes, they actually change the whole drain plug every few oil changes.
Reactions: FZipper09
The washer is not designed to stop leaks. It is designed to prevent over tightening of the engine oil drain bolt. Hence the crush washer name.
Discussion Starter · #16 · (Edited)
Thanks for the picture of oil filter gadget (WalMart?) - I have the rubber strap type (slips easily)... Don't know why they have to put them on so tight for... I've had to punch holes in them before with screw drivers... To get a grip... erhhh!!
http://www.fz09.org/forum/6-fz-09-general-discussion/3021-low-profile-drain-plugs-5.html
Never slips and very low-profile.
I have never had to replace a drain plug gasket on anything. Never had a leak either. In a crunch I ran without a drain plug gasket entirely (found it later) on one of my dirt bikes and it still didn't leak. If it's not cracked or paper-thin from over-tightening, there's no reason to replace it IMO.
1 - 20 of 27 Posts
