1 - 20 of 32 Posts
$85 for poorer filtration? I'd keep buying $6 filters.
Hey Captain,
Where do you get $6 oil filters???
Everything Ive found is around $12 on up.
Ill stay away from factory Yamaha filters thank you very much. They were not rated very good.
Been using Vesrah.
They make 'reusable' stainless filters for dirt bikes too and they're junk. Try replacing your paper coffee filters with a 'reusable' strainer and then look at all the grounds in the bottom of your mug. Same concept.
I was talking with one of the members in my riding group yesterday who uses one on a GSXR. She highly recommended it, but it was merely motivated by cost. Filters are a fraction of what other maintenance items cost when owning a motorcycle. It probably does a decent job, reviews on Amazon seem good. But, changing oil is a 10 minute job, no need to make it a 30+ minute job by adding a filter that has to be cleaned.
Kind of funny. I work on car from early 30s to early 70s for the most part. Those cartridge style filter is what they use and got upgraded to the normal spin-on filter that we know today. I saw those cartridge with felt, paper and steel mess filters... no new invention here.
Is this a better product? Maybe if you can clean it properly, if not it make it worst. Sort of look a bit bulky too... I'll stick to my Fram disposable filter.
Hey Captain,
Been using Vesrah.
$12 for a filter? What are you buying?
Oil filters are $3-4 at any autoparts store and even Walmart
I never said I was buying anything. What I said was that the prices I found were around $12 on up. I know our local "Stealership" charges $15 for a factory filter. Several other local shops are in the $12 and $13 range for Hiflo, Emgo and K&N. I dont use Fram filters which is what our local Walmart and AutoZone carry. Never been a fan of Fram.
Wow, Good price and its a very well designed filter.
Thanks, I think I will start using Purolator.
I paint the puke brown filters black before they go on.
I've been using the PC racing stainless filter on my vmax for years. No problems at all. I like that I can easily see anything caught up in it when cleaning. I can change the oil anytime without having to run and and get a filter. They claim you get higher flow rates and oil cooling.(I don't rally know). Be careful on what the paper filter guys claim as to size of particle. I read some report that one filter co claimed 20 micron on their paper filter. Tests showed it was closer to 60. If you plan on having your bike a long time it may be a good investment.
We need some actual data. How well does it actually filter particles? How many microns? A great way to get higher flow is to simply allow more particles to slip by.
Same with air filters.
1 - 20 of 32 Posts
