1 - 4 of 4 Posts
I have a quickshifter on my mt09 now. I don't seems to get the right setting. Mostly of the time the upshift sounds loud and sometimes it's sounds really smooth. Shouldn't the QS upshift shld be always smooth and not loud sound? Any help here?
I won't be home until next Monday... the thing with those shift without lift thing is you can't milk it. The higher the RPM but better it shift. I don't use mine much unless Im over 6K RPM
I have a QS operated by PC on other bike. I have the delay set for full-throttle high-RPM shifting, and it shift smooth. When using QS at lower RPM's, the delay makes for a bit of a clunky shift. I believe mine doesn't kick in until beyond 6K.
I found it to be trial and error. I tried 10ms increments at a time until I was happy with it.
As you get in the higher gear the split can be shorter since the gear split are closer (rpm drop) between gear.
PCV base settings are very safe, kind of way too long cutoff.
1 - 4 of 4 Posts
