1 - 12 of 12 Posts
Does the coolant have anti freezing capabilities???? I just did a search on which coolant to use and the one suggested stated freezes at 32 f......just curious if I need to winterize it or not.....
just saw to use yamacool....will pick some up later this week....the other was for race engines....
Think most coolants will be fine, unless you plan a tour to North Pole
Read what it says on the bottle ( dont dilute)
I use (or rather my dealer) Yamalube that can handle down to -35*C
32f is 0*C , so obviously not gonna cut it when temperature drops to that.
Some race coolants seem to have a high freezing point, probably because people dont race during winter.
I would hope that all of these bikes shipped with coolant with adequate freeze protection ..if not, this will be the first time I have bought a bike that hadn't.
I just checked my bottle of YamaCool it says it is good for -62 Deg F (-52 Deg C).
So it should be fine if you have YamaCool in your 09.
The manual says 1:1 High-quality ethylene glycol anti-freeze containing corrosion inhibitors for aluminum engines.
IOW, it does NOT freeze at 32f
i have read most of the threads about running too cool but I think mine runs too hot. I am not going to ride below 60 and I am amazed at how fast it gets hot in traffic once it does reach operating temps. 170's if I never have to stop is a cool as it gets, 180s to 190s at stop light and 215 and up if there are more than 2 or 3 lights. It seems to go up much faster than it comes down.
So my question is, has anyone tried any of the water wetter products like Red Line or Supercool? I have had good results in the car (very noticeable when pulling a trailer) but it seems antifreeze seems to come in very specific flavors now days and I am afraid to dump some in. I mean, the fluid is blue!
Thanks,
Foutainclimber
Water Wetter contains nothing for freeze protection, in other words, it will freeze at 32 degrees F, as it is mixed with water when used in a cooling system. It's certainly not recommended if you live in an area that gets below freezing, unless you know for sure that you can keep it in a temperature controlled location.
YamaCool is a coolant and an antifreeze. YamaCool is good for -62 Deg F (-52 Deg C), it is also good for +272 Deg F (+133 Deg C) with a 15 psig pressure cap. It also notes to "Do Not Dilute" on the bottle of YamaCool. If you add water you will decrease the coolants boiling point.
Distilled water boils at 0 psig (14.69 psia) at +212 Deg F (+100 Deg C) (14,69 psia at sea level)
So at 15psig (29.69 psia) water boils at approx. +250 Deg F (+121 Deg C)
So distilled water should be ok as a coolant, just beware that it does not work as good as a proper coolant does. Plus it will freeze at +32 Deg F (0 Deg C).
Plus, just water will have zero lubricating qualities for the water pump.
Engine Ice is a good product also! Sportbike Track Time even allows it in the Intermediate and Advanced groups. E.I. will take the freeze protection down to -26 F, which should be good for a lot of the owners other than the Northern folks if left in an unheated storage area.
1 - 12 of 12 Posts
