1 - 2 of 2 Posts
My 2020 Mt09 (new purchase end of March) was low on coolant in the reservoir the other day. I was running late for work, and the only coolant I had on hand was Honda HP. I added enough to bring it from the low to full cold line. I assume the dealer used Yamacool when built.
Anyway, should I flush the system and refill with coolant of the same type, or will I be Ok as they are both ethylene glycol based?
Dealer doesn’t put coolant in new bikes. Factory fills all fluids except gasoline.
You should be fine with what you put in.
1 - 2 of 2 Posts
