1 - 5 of 5 Posts
What's guys.....I recently installed the Arrow exhaust and was wondering if anyone thinks it be good to put some heat shield tape on the bottom of the oil pan.....not sure if yalls is the same but my collector pipe pretty much rest on the pan and I can't adjusted the exhaust to get it off....As soon as the springs are on it pulls it tight so.....was wondering what's yalls thought were?
Thanks
I've got an Arrow full system too and mine has 1/4 to 3/8" gap between the oil pan and the collector.
Yea, the collector requires a good bit of "adjustment" to get it to fit correctly. There should be a little bit of clearance between the oil pan though otherwise you'll eventually wear through something... Maybe loosening the headers up and adjusting/retightening would help.
1 - 5 of 5 Posts
