The pressure plate itself is in correctly but the triangular metal plate was in flipped upside down like you pointed out. It’s unfortunately still not working. Do you know when you put the clutch back together did you need to restart the bike before the clutch started working properly? I put it together and tried engaging the clutch after putting the cover back on but it’s still not releasing the gear…If you put the pressure plate in backwards like I did the first time on my bike, it won't work, trust me. I put the one in my wife's bike right and it was perfect. That is why I saved the picture.
The Pull rod is not engaging on the cable lever. You should not be able to move the clutch cable lever by hand with-out alot of force. Yours is moving to easily. Put some grease on the Pull rod so as engagement to the lever will help to line up...Alright here it is. I’m putting the clutch back together and it won’t disengage the gears. Tell me what I’m doing wrong!
Disregard the crispy metal plate at the end - that’s the old plate as I bent the one I ordered - getting a new one tomorrow.
Are you suggesting placing grease on the pull rod teeth? Is there a grease you’d recommend?The Pull rod is not engaging on the cable lever. You should not be able to move the clutch cable lever by hand with-out alot of force. Yours is moving to easily. Put some grease on the Pull rod so as engagement to the lever will help to line up...
Yes used lithium soap base grease on the teeth and on the base of the pull rod to keep it from moving while attaching the cover .Are you suggesting placing grease on the pull rod teeth? Is there a grease you’d recommend?
So even with the cover completely on you think there’s enough wiggle room for the teeth to not align with the connecting teeth? Seems very snug. But placing grease on the base of the pull rod is a smart move…Yes used lithium soap base grease on the teeth and on the base of the pull rod to keep it from moving while attaching the cover .
Keep playing with it until you can place the side cover on with-out any bolts placed and then pull on the clutch lever a bit and it will push the cover outward then you know they are lined up .So even with the cover completely on you think there’s enough wiggle room for the teeth to not align with the connecting teeth? Seems very snug. But placing grease on the base of the pull rod is a smart move…
Yes it does do this every time I place the cover on and try to align the arrow and dot on the cable arm. I cycle through and it pushes the cover outward every time…But once I have the cover bolted on there isnt enough resistance when I push on the cable arm to disengage the gear…it just pushes in toward the body (simulating what the clutch lever at the handlebar would be doing) and the only resistance is coming from the spring that’s on the rod that keeps the arm in the correct position…Keep playing with it until you can place the side cover on with-out any bolts placed and then pull on the clutch lever a bit and it will push the cover outward then you know they are lined up .
I believe the neutral resting spot with the spring in place is where the dot and arrow need to align which is how I have it on mine. Will take a look at it againI think you need to rotate the arm past the dot.
Check out this video
