1 - 10 of 10 Posts
The clutch cable is frayed and is to be replaced under warranty. Problem is its on back-order from Yamaha and dealer says will be at least 3 weeks. Anyone know of an aftermarket replacement? I've searched but come up with nothing :(
Wow... that's kinda crazy.
sorry I can't help with leads on aftermarket options, but you could always make a stink at the dealership and have them pull a cable off of a bike sitting on the showroom floor... if they have one that is.
mind if I ask where it started fraying, and how many miles you have on it?
They have no other FZ09's in stock unfortunately so pulling a good cable not an option. It is letting go right at the lever. No warning, wasn't tight or anything. Just started getting loose and when I went to adjust found the damage. Only 3500km.
Auto part Hand Metal
I'm at 4000km just check mine is good..but nice to know.
Checked mine too. I was a bit concerned that my perch adjuster was getting further and further out. I decided to roll it back in and adjust it down by the case. I have never had a bike that I had to adjust the clutch so much and that includes motocross bikes that I abused the clutch on. It has me a little concerned about the plate life.
Actually, if the plates wear, your cable gets tighter not looser. When it gets looser and looser it usually is the cable losing strands.
Motion Pro makes custom cables that are usually about the same cost or even cheaper than OEM and generally are better quality.
4000 miles on my bike and I usually power it up in second and hit third on the way up without using the clutch. Every blue moon I will flick the clutch in third gear to get it up, but very infrequently.
I rarely adjusted the clutch cable on my CBR954RR, and rode it the same way. My wife's R6S has had to adjust the play a bunch too.
1 - 10 of 10 Posts
