1 - 14 of 14 Posts
Next projects:
-USB Charger for my cell phone. Going to make a 12V socket DIY
-CRG Arrow bar end mirror (soon)
-CRG Spectrum levers (soon)
-Akrapovic Carbon exhaust (for christmas)
-Power commander (for christmas)
-Stoltec ECU Flash (not sure yet)
-Evotech Front fork slider
-Evotech Rear axle slider
-GB Racing Engine cover set
-R&G Racing Radiator Guard
-AHR retrofit (next year)
-Motodynamic integrated tail light (wait to see final product)
And some other projects not listed but will be posted
You gave me an idea of where to put the front turn signals. Dig the lights.
Nice looking build, looks good!
Cheap mod that cost 13$ CAD at Canadian Tire....and took 15min to install...a dual USB connector with 2 Amps for quick charge ;)
What you need:
-Terminal connector for the battery
-Fuse holder
-3 Amps Fuse
-12V socket with about 6 inch of wire
-A 12V to USB converter.
Simple, Cheap and Cool mod: Headlight switch!
What it does? Check this video:
For this mod uou will only need some Male and female connectors, a switch and a wire.
1-Dissasemble your headlight assembly
2-Disconnect the headlight connector.
Black is for ground
Yellow is for the highbeam
Green is for the lowbeam
3-cut the green wire and make some female connector with each end.
4-Run a wire from the headlight assembly to the battery
5- Connect one end of the wire to the switch
6- Connect the other end of the wire to each connector of the green wire.
Your done! Start the bike and enjoy the possibility of having only the auxilary light ON! :)
Yet another cheap and simple mods! Go Pro mount under the headlight using the horn braket.
The view:
What you need:
-Do the Horn relocation mod.
-Buy a M6 x 12 bolt
tats it.
wow, I wondering about putting the GoPro under the headlight but was worried about the clearance with the front tire. Looks like your front came in contact with the camera after that wheelie. Thanks for sharing.
1 - 14 of 14 Posts
