1 - 3 of 3 Posts
Hey guys, I did a search but had no luck answering my question. Basically Im trying to find out if it's possible to change the default map from standard to A mode when you turn the bike on.
Cheers.
As far as I know the only way is to do an custom ECU flash and have it defaulted to a different mode than STD mode.
It is possible, but you need to have your ECU flashed in order to remove it as the default setting...
*Edit*. Rocky beat me to the post---curses, foiled again! lol
1 - 3 of 3 Posts
