1 - 3 of 3 Posts
Brembo RCS19 Brake Master Cylinder gives you the best of both worlds.
Brembo has designed the RCS19 Brake Master Cylinder for the rider who requires more brake performance and variation in brake lever feel when compared to a stock master cylinder.
The Brembo RCS19 Brake Master Cylinder gives you the option
to choose between (2) ratios:
19x20 & 19x18 with just the turn of a screw.
Included in our kit is a Microswitch for the Brake
For Racers, the adjuster knob has been relocated to the same position as the 19x18 Billet Folding Brake Master Cylinder that is used by Valentino Rossi and Nicky Hayden in MotoGP and WorldSuperBike.
Two springs have been installed to ensure constant contact between the lever and the pushrod to ensure a longer lifespan.
For more information & to watch our Youtube Video, just click on the links below.
>> Brembo RCS19 Brake Master Cylinder <<
Yes I have that MC, very nice, pretty much stick with one setting once set there. Problem was, had to buy the $160 folding Brembo clutch lever too just to match on the other side!
Yea, it's tough when you have to have them matching. ;-)
But they look oooh so good.
1 - 3 of 3 Posts
