1 - 2 of 2 Posts
ALL NEW Brembo "Corsa Corta" 19RCS Brake Master Cylinder
The NEW Brembo 19RCS CORSA CORTA allows the rider to tailor the “bite point” exactly where they want it, with an easily accessible selector on the top of the master cylinder itself.
As with the RCS19, the New Corsa Corta Brake Master Cylinder gives you the option to choose between (2) ratios: 19x20 & 19x18 with just the turn of a screw.
The selector operates a cam mechanism to let the user choose between three different responsiveness settings.
a) Normal setting
- indicated on the master cylinder with the letter N, the bite point starts more gradually, making it suitable for city riding or braking in poor grip conditions.
b) Sport setting - indicated on the master cylinder with the letter S, the beginning of the bite point is shorter than in the N setting. This setting produces a more dynamic response suitable for sportier riding.
c) Race setting - indicated on the master cylinder with the letter R, the position of the cam mechanism shortens the initial stage of the bite point even further to produce the same immediate response of the master cylinders used in MotoGP, letting the rider reach the bite point of the brakes instantaneously. This setting is ideal for use on the race track, where every hundredth of a second shaved off a lap time counts.
Included in our kit is a Microswitch for the Brake
>> BREMBO "CORSA CORTA" 19 RCS BRAKE M/C <<
Discussion Starter #2
Finally received the first shipment.
It's not as many as we ordered..... But it's a start, from what seems like forever ago.
Congrats to all those who've stuck it out. They are on the way to you.
1 - 2 of 2 Posts
