1 - 7 of 7 Posts
Hello,
I have the brembo m4.32 calipers from gsxr1000.Seems that working without spacers with stock brake disks but i will also add some 320mm disks.Anyone knows what spacers and bolts do i ll need for the setup.
Thanks
MT09 ABS
11 mm spacers and 80mm x 1,25pitch bolts for brembo m4.32.
Order done!!
... and if you're looking for extra braking power, a pads swap will give you what you're looking for... I tried out the DID Zcoo EX and the EBC EP . They're both good but - personally - I like the EBC more.
The stock ones have far less bite... The only thing to keep in mind with the other two is to warm up the pads/disc with the very first lever squeeze, since they're still cold or if they cooled down after a while. One hard squeeze is enough and the more you brake, the more they bite.
Anyway if they're cold they still bite more of the stock pads, so it's a win-win situation if you don't mind to spend more money to buy them instead of stock ones
1 - 7 of 7 Posts
