1 - 20 of 25 Posts
Hey guys, long story short I hooked up my jump start cables the wrong way, blew the 50a fuse changed it out, bike lights up but turns but doesnt start up. Any Tips?
Blown fuses other than the 50a ?? When you turn the key to on do you hear the fuel pump prime ?
So you are saying the starter cranks over ? Oh and what year are we talking about ?
Do not know How to do that.
If you only visually inspected them, there is a good chance you missed a blown fuse. Get a volt meter, check for continuity of all fuses.
Sorry I do not have a wiring diagram on the SXR so I can not see if your missing something....
Starter solenoid blown? Have you tried bump starting it (which would indicate starter problem if it fires)
Oops, didn't read, it is cranking. Ignore.
break it down to basics
1) its turning over so it not in the starting system
you need 3 things to have a fire
spark, fuel and compression
we can assume you have compression
if you can hear the fuel pump prime we can assume it has fuel
which leaves spark, to verify you do not have spark pull a plug and plug it into the spark plug wire and hold the tip against motor and see if you have spark jumping across the electrode
then you have to trouble shoot the ignition system. Honestly other than a fuse and the ecu not sure what else there is to it on a modern bike. Can anyone help me out here?
Oh Hell should have thought of this ...Try push starting it !! I would try this first B4 having to get to the plug wires !
Let us review. " I hooked up my jump start cables". And why was this necessary? Maybe your battery is pissed, that's my guess. On a modern bike the battery is part of the circuit and not just for starting so I would try a nice fresh battery.
Discussion Starter · #20 ·
Yeah bro my battery is dying(replaced it after the jump start) but I solved the issue… one fuse blew and I missed it when I was inspecting them visually. Later I checked for continuity and found the blown fuse. Motorcycle works perfect
1 - 20 of 25 Posts
