1 - 4 of 4 Posts
Anywone can tell me the right quantity to put in a full tank of BG44K injector cleaner, the can only said that they can treat 20 gallons of fuel?
And it is recommanded to change oil after the treatment?
Usually injector cleaners like Lucas can treat 6-20 gallons per bottle. And Seafoam treats one gallon per ounce of cleaner. I'd do a 1/4 or 1/3 bottle. It won't hurt if you go a little over. You don't need to change oil when you do it, but changing oil is a good way to remember to put some injector cleaner in as part of a regular maintenance routine.
**If I'm wrong someone speak up!
Do i need to change oil after?
Nope. The cleaner removes deposits in the injectors and valves and blows it out the exhaust. Never messes with the oil
1 - 4 of 4 Posts
