1 - 2 of 2 Posts
Saw somewhere that someone was using tennis racket tape on the handgrips to reduce the vibrations thru the hand grips. In the past I have used grip puppies to help reduce the vibes and make the grips bigger - all of which helps. The last pair of grip puppies must have been old as they lasted less than a year before ripping apart. The use of a sporting tape seems like a tougher solution.
So I started looking on-line and found that a shock absorbing tape is used on baseball bats. OK, lets give it a go.
1 - 2 of 2 Posts
