1 - 3 of 3 Posts
Hi,
I can't seem to find this information to be 100% sure. I want to install 3 led fog light on my bike with a switch, but I want them to be control by the bike as well so it never drain my battery. I'va already connecte and aux. usb plug on my 2A connector. The setup for my fog light will most likely be higher than 2A, but lower then 5A. Is it possible to use the grim warmer connector for my fog light or it can cause a problem?
I don't think it can cause any problem since it's juste a circuit with a fuse, but, since the quick shifter circuit can't be use for anything else, I want to be sure about this grip warmer connector.
Thank you
There is a dedicated accessory lighting harness under the right side plastic panel by the fuel tank. It's live when the engine is running.
1 - 3 of 3 Posts
