1 - 4 of 4 Posts
Hey guys,
For anyone who has PC5 installed on their FZ09 (and if also tuned that would be great), could you please send me your details of the calibration of gear positions?
I have accidently reset the first and second gear numbers .. and need some help getting them close to how they were (until i get it tuned!)
Thanks
You can just put it on paddock stand and go through the gears while the bike run. You don't have to give gas... hit calibrate for each gear and blend or something like that when you're done. If you're not using any of the advgear feature I won't worry too much for now... it will still work just fine.
As far as map, you're more than welcome to try mine. Only thing is you need to hook up the MAP sensor (pink wire) to the extra PCV channel. You need to set few settings but it's very easy. 4 numbers to type in!
1 - 4 of 4 Posts
