1 - 8 of 8 Posts
I think I have a coolant leak. This certainly looks like dried antifreeze to me. Problem is, I can't find where it's coming from. Has anyone else experienced this before?
159525
Discussion Starter #4
Is your radiator or reservoir low?
Ride Sane.
It's not beneath the 'low' mark but it's lower than the last time I checked. The spray pattern looks to be as if it's spitting out somewhere a little bit at a time.
Check that the overflow cap is still on correctly.
In addition, Look at the coolant level when bike is completely cooled down and on side stand (on flat ground) so you can compare levels.
1 - 8 of 8 Posts
