1 - 9 of 9 Posts
Hey guys, for those that have installed the akra carbon kit - do you have a check engine light on?
My o2 sensor seems to be connected fine, although I did struggle with the install.
Cheers
Mine didnt come on after install at all. You may have a damaged O2 sensor especially if you twisted it a lot to unscrew it.
Bite the bullet and take it in to the shops I reckon :(
Cheers
I had light come on after installing exhaust as O2 sensor plug not fully home (cable run very tight). Dealer cleared at service, fine since.
Did you happen to turn the key on before connecting the O2 sensor ? That would do it !
So a follow up on this - once i plugged the 02 sensor in properly and went for a decent ride, the check engine light turned itself off and no issues now 👍
Good Sir: A special thanks to you for letting us know the resolution. This will surly be a recurring situation and now an answer is just a click away.
Many of our new members come on the board with a question and after receiving a variety of possible solutions they disappear without closure and leave us wondering. Not so in this case.
1 - 9 of 9 Posts
