1 - 4 of 4 Posts
so new guy from Canada just wondering how hard it is to access the air filter under the tank do the plastic pieces up front come off with the tank or do they need removed first some pointers or pics would be nice every thing else seems be fairly easy to get at thanks Ray
The fake "scoops by the tank leading edges come off (the mesh grill bolts do not!) first.
Next, press in and release the four fasteners holding the plastic panel at the nose of the gas take to get that part free.
Remove the seat and undo the two 4mm allen bolts holding the rear tank mount in place. Prop the tank up and disconnect: the two drain hoses, pump electrical connector and lastly, the fuel line. If you aren't familiar with the quick connector, there's a plastic cage that snaps part way sideways away from the hose - exposing places where you simply squeeze and pull the hose free. You should not have to struggle.With the fuel line off, unbolt the two pivot bolts on either side of the tank's leading portions. It should then lift free. The airbox has a couple of bolts around the perimeter plus a large vent hose down the left side and the ECM connectors on the right. All undone? What's left are the three intake boot clamps and one more vent hose underneath.
Reactions: phm14 and KoolAid
1 - 4 of 4 Posts
