1 - 18 of 18 Posts
Hello everyone
I just got a new fz09 about a week ago I've done 400 miles on it so far . The bike is Great but I am facing this problem is for the last 3 days it's just weird but I feel like the engine is less powerfull, I remember I pinned it and the front wheel lifts up easily on B mod now am driving it standard mod and I pin it on first gear the wheel barely gets of the group it's just wired it's like I removed my engine out and replaced it with 450 cc , I don't know what to do and what kinda problem could It be , I would really appreciate any helps
Clogged air filter? Any leaves, plastic bags/garbage blowing around on one of your rides?
Did you go to a different gas station or use a low grade of fuel?
Dead spark plug..........running on two cylinders ??:indecisiveness:
Have you changed suspension settings or how you have your body weight on the bike? That can make a difference in how easily the 09 wheelies.
Have there been any error codes on your display? Will you be taking it to the dealer for the 600 mile service? See what they think.
I use fuel super 98 it's the best thing out there ,and yes it's red :p it could be the spark plugs like r1 Dave said I will take to the dealer and probably dyno to make sure the horse power r still there , thank you guys
I wanted the Orange one but it doesn't come here to the United Arab Emirates only the red and the race blue , I wish I had the Orange one
If the ECU detects certain error conditions doesn't it go into a mode with reduced power? Or is that some other vehicle I'm thinking of...
If one of the plugs was bad you'd certainly hear it with a triple, wouldn't you? I know there's people out there who can pick out a bad cyl in a v12...
Youssefz09
When you figure this out, please let us know what the story is.
I experienced a similar thing. I just got back from a dyno test (at about 1500 miles) to try to figure how bad the problem was.
I maxed out at 103.78 HP. I was imagining maybe I was down to about 85 HP. I know others get higher readings than mine, but I'll probably simply live with it as is, unless I hear of some magic (and reasonably priced) solution.
Thanks!
Fred
Yousef, Can you post a [ic if you can of a race blue FZ09, I would have def go it if they have it here in the US.
I'm with V2Bob on this one...just after I got my bike, it would wheelie *easily* in 1st and 2nd
Once I had stiffened up the suspension (reduced the sag and squat under power) the bike has become far more civilised.
The impression is less power, but she still pulls strongly.
^ I thought it was the opposite. Doesn't saggy suspension make it harder to wheelie?
104whp is about right. All dynos are a little different, but for a stock bike, that seems spot on.
Go ride a Vespa, then get back on your 09, problem solved.
1 - 18 of 18 Posts
