Hi Guys I have a 2018 MT09. Recently I had the front tire replaced. When I put the wheel back on I didn't realize that I put the side with the abs sensor on the opposite side. I didn't take the bike out right away but when I did the light came on, I rode it a total of about 20 miles before realizing the wheel was put on wrong, I swapped it with the correct direction of the tire with the abs sensor on the right hand side but the lights still persist. I unhooked the battery and reconnected and that didn't clear it either, any other way to get into diagnostic mode to clear it?
I noticed when I initially put the wheel back on and rolled the bike I heard a clinking sound as if something was being rubbed/not spinning freely. Now even with the wheel and ABS sensor on correctly there is still a slight clink when I am riding the bike but not when I am moving it around myself.
I also unscrewed the abs sensor and put it back to see if that would clear it. I am thinking maybe the abs speed rotor or the sensor itself got ate up when it was on the wrong side? Thoughts before I go out and purchase one or the other?
Thanks!
Thanks!
